Knock heard when reversing
Old Feb 20, 2011 | 04:43 PM
alanhancox's Avatar
alanhancox
Default Knock heard when reversing
Hi,
When I select Reverse and start reversing, while in the process of going backwards there is a sound of a sharp knock. It appears to be coming from the front of the car....it seems to be clutch related as if I raise my foot off quickly... and more so when reversing up a hill this knock will happen. If I gently raise my foot off the clutch on a flat road, then nothing happens or.. once it has knocked once it won't happen again unless I drive forward and then reverse. It is intermittent as it will not always happen, never in forward gears or motion. I have been told that it could be the brake pads catching on the disks...but its difficult to say exactly where the noise is comming from Gearbox, Pads etc. but seems central most of the time. The gearbox works fine and so does everything else except for this knock.. must mention that new CV joint fitted on the passenger side recently.
Car is a Focus estate 1.6 Ti vct 55 plate.
Any Ideas....Cheers
Old Feb 20, 2011 | 06:46 PM
Chaz888's Avatar
Chaz888
can be a lot of things box mounts pads as stated maybe the other cv? try with someone outside the car .
Old Feb 20, 2011 | 08:14 PM
alanhancox's Avatar
alanhancox
Cheers for that, the CV was changed because the garage broke something when they changed a wheel bearing that was attached to the the CV (some sort of rod) but I know the CV's have been looked at and are fine and no sound when turning corners..will get a garage to look at the mounts, I assume they are the engine mounts (lower) as the engine feels quite sturdy in the bay with no lumpiness when accelerating. The knock sounds like a light knock but very much metal to metal....Thanks again
Old Feb 21, 2011 | 03:52 AM
Chaz888's Avatar
Chaz888
just a hint dont use that garage the bearings are in the hub the cv gos through the hub thay brake a rod? what rod ? then change the cv why?
Old Feb 21, 2011 | 04:43 AM
carlfiesta999's Avatar
carlfiesta999
dual mass flywheel about to go bollocks? diesel?
Old Feb 21, 2011 | 11:22 AM
Sp3no's Avatar
Sp3no
Gearbox mount, they knock when they have gone, very cheap and easy fix if it is, buy the poweflex polybushes for the mount, think they are Ł27 burn the old ones out, push new ones in and you will have a lovely feel to the gear change and the bush will last the life of the car.
Old Feb 21, 2011 | 11:23 AM
Sp3no's Avatar
Sp3no
For his wallets sake i hope not
tankybaby66
Feb 6, 2016 02:24 PM
Marv888
Sep 26, 2015 03:44 PM
cameron2
Sep 20, 2015 04:30 PM
