Saff 4x4/Focus RS brakes
Old Feb 20, 2011 | 11:07 AM
blackcossie's Avatar
blackcossie
Default Saff 4x4/Focus RS brakes
Can i use the focus RS front brakes on a 4x4 saff cosworth and what would i need?
Old Feb 20, 2011 | 12:33 PM
Big_Mike's Avatar
Big_Mike
I've just bought a set for mine. You can, just need a set off brackets for them to fit a 4x4 hub. I know there is someone who sells a kit to fit a 2wd hub, but reyland do a bracket to fit.
Old Feb 20, 2011 | 03:03 PM
blackcossie
cheers m8
Old Feb 20, 2011 | 06:59 PM
Sta1n1's Avatar
Sta1n1
didn`t think you could use the disc`s from focus rs on a 4x4 ? or am I totaly wrong now ?
Old Feb 20, 2011 | 07:05 PM
RS Stevie's Avatar
RS Stevie
deffo cant cant use FRS disks on a 4X4
Old Feb 20, 2011 | 07:18 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
i also got told you couldnt i almost bought some!
Old Feb 28, 2011 | 11:19 PM
Sta1n1's Avatar
Sta1n1
would it be possible to machine out the center and make a 2 piece disc/rotor out of a focus rs brake disc ? or will this weaken the disc or something ?
Old Mar 1, 2011 | 09:29 PM
anglia105e hinson's Avatar
anglia105e hinson
I bought 2 of these a while ago havent got round to fitting them yet. You got any progress yet mate?
I was looking to get second hand bells and rotors for a 4x4 and making brackets for them.
The only thing I was worried about is the clearance between the outer face of the caliper and the inside of the wheel. I'm running 8x17 hockenhiems at the mo.
Old Mar 4, 2011 | 09:30 AM
Big_Mike's Avatar
Big_Mike
I've got some 8x17 hocks, should be fine. what offset are they? I'll probably get some bells made up, as the discs i got with them are worn anyways. It's still cheaper than buying some ap's!
Old Mar 4, 2011 | 09:42 AM
Graceland's Avatar
Graceland
Team HOTHOT!
You can use the calipers (I did) but you will need some bells and rotors to suit along with some brackets
Old Mar 4, 2011 | 07:15 PM
daz-cos's Avatar
daz-cos
hi could u tell me who sels the kit for 2wd as im after some
cheers daz
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
