Esc Cos speedo
Old Mar 30, 2004 | 10:23 PM
gekko's Avatar
gekko
Default Esc Cos speedo
I have a small turbo (1995) Esc Cos,and the speedo dial does not light up.
All the other dials are fine. Are they lit by bulbs or a glowing string?
is it an easy repair, what are my options?
Old Mar 31, 2004 | 06:52 AM
cossymad's Avatar
cossymad
Neither
They are basically made up from electroluminescent paper that glows when an electric charge is put through it
I reckon if only the speedo is not lighting up, then it sounds like a broken connection....if you are luckily you could repair it.
I know of a set of clocks for sale if you can't fix it!
Old Apr 1, 2004 | 08:45 AM
gekko's Avatar
gekko
Can you recommend anybody that would be able to take on a job like this.
Old Apr 1, 2004 | 04:48 PM
dave green's Avatar
dave green
The speedo assembly is not hard to remove Tel.
Old Apr 1, 2004 | 07:01 PM
gekko's Avatar
gekko
Hello dave,
I thought you were comming round to see the car last Sunday!
I hope the problem is just the voltage converter.
I might have a look at the weekend.
Tel
Old Apr 1, 2004 | 08:01 PM
dave green's Avatar
dave green
Me and big gaz were comming round. but something croped up. See you soon no doupt,
Dave
Old Apr 4, 2004 | 04:53 PM
there is no bulbs its just the electro paper
Old Apr 6, 2004 | 05:05 PM
Take the cover off so you can touch the speedo dial and at the top right there is a tiny button that you can push till you hear a click if the light doesnt come on then its a broken connection Id say.
cossie brad
Sep 29, 2015 02:38 PM
`spotty
Sep 25, 2015 11:41 PM
IainRS1700T
Sep 25, 2015 06:44 AM
sto6enc
Ford Mondeo Including ST
Sep 21, 2015 11:31 AM
Bransby
Sep 14, 2015 08:54 PM
