4x4 Saff, underside Resto project (updated 11th November)
What was a case of changing my rear bushes has now turned into a full blown underside restoration project...
Only problem is Im not sure how far to take it and I can see things getting expensive
As you can see it was in very bad need of a clean up...
The previous owner keept the car on her front drive/garden
and the wet grass has taken it's toll on it...
When I took the fuel tank out the was so much old grass that had rotted the tank to bits
Ive got it fully stripped now ready for sandblasting
And needs welding in the common places (chassie rails)
I will post more pics as I go
Originally Posted by Dean Saff
Beware,, Dont park on wet Grass
looks like a fair deal to me whet your doing with the cossie mate, saving her life is the best you can do
good luck mate and keep us updated
My donor car is no longer available, because i fell out with the wanker that runs teh scrapyard!!! Both in the same boat chops! I may have found a company that still manufacture the panels but i'm not 100% sure yet i'll let you know!
Sorry to hear that, what a bummer. The guy took mine down the yard today and couldnt be bothered to inform me.. Its the size of a washing machine now
If you have found somewhere that still makes new ones please let me know, nice new ones would be real nice
Originally Posted by NOSRSt
My donor car is no longer available, because i fell out with the wanker that runs the scrapyard!!! Both in the same boat chops! I may have found a company that still manufacture the panels but i'm not 100% sure yet i'll let you know!
My rails actually wernt that bad, one side is perfect, Little bit of patch work may surfice..
Anyone know whats the best thing to neutralize rust..
I just brought a job lot of red oxide primer from ebay was hoping it would do the job??
got some more pics of all my bits
before they go for blasting
Both the ABS sensors busted when taking them out..
This is only fit for the bin
started cleaning back the underside couple bits of welding needed
Will be well worth it when done m8
A lot of surface rust under there,but quite solid compared to some others
Pump/filter carrier are still avail from Ford,about Ł35 IIRC
ABS sensors Ł75 each IIRC
Keep up the good work
Yours has a bit more surface rust than mine but your rails are better than mine at the bottom. I have another complete fuel pump bracket which im having coated at the moment so I have a spare one now, You can have it for 15 if you want? its blasted and powder coated silver it is missing the pump bracket though same as yours
any pics?
Lads the rear rear rails that i thought i had got my hands on were just the rear boot floor sections only, that may or may not be some assistance to you two. For the record i'm now having some new ones fabricated.
Done some of the welding myself
...going ok..
Found some more welding needed in the front footwells
I have a problem, I cant get any bolts for the drive shafts,Ford don't sell them
Anyone have any ideas?...
Will get some more pics up soon, All suspension back and being painted at the mo
I used a white stone gaurd with a shutz gun.
went on well, but reacted in a couple of place were the rust primer wasn't dry
Hoping that when it dries I'll give another coat and it should be alright..
Thanks for your views guys.
All suspension parts now painted and lacqard.
And Ive just put gloss top coat on the underside(will put pics up soon)
Heres some of the suspension bits
Got the gearbox back in today. I would advise not to do this on your own,
I did, 2 jacks and alot of hot sweaty fun...
I also put my new Powerflex beam bushes in. Pain in the arse that was.
I wont be doing that again in a hurry ended up squezing them in with a vice.
Beam to go up next. I will put some more pics up soon.
What about the fuel lines and hoses, are you replacing them aswell??? If so where are you getting them from just out of interest as i want to undertake this work on my car in a few months.
The return I had to salvage as is unavailable from ford,Rubbed it down with emerey (spelling) papper and painted in hammeright silver then lacqured looks like new.
Ok cheers, i think i will try and source some lines/hoses before i start so i knw if i have to do the same. What about the brake lines, are they still available??
Cheers!
Cheers!
I know there five stud but they should fit.
