Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
HELP 1.25 fiesta no spark
Old Feb 17, 2011 | 08:09 PM
sirloveyou's Avatar
sirloveyou
Default HELP 1.25 fiesta no spark
Hi
brought a fiesta which dosent run as a present for my mrs
whose birthday it is tomoz
Ecu been tested all ok, fitted a new crank sensor and cam sensor but no spark ???
please help need to get her running !
cheers
Daniel
Old Feb 17, 2011 | 08:58 PM
martysmartie's Avatar
martysmartie
Is the coilpack/wiring good?
Martin
Old Feb 17, 2011 | 09:02 PM
sirloveyou's Avatar
sirloveyou
yea looks good
Old Feb 17, 2011 | 09:10 PM
sirloveyou's Avatar
sirloveyou
look at my other post
see what you think
https://passionford.com/forum/techni...ml#post5346477
Old Feb 18, 2011 | 06:58 AM
Bailes1992's Avatar
Bailes1992
Originally Posted by sirloveyou
yea looks good
It might look fine, but could still be nackered. Replace the coilpack, HT Leads and sparks. Will cost you about £80.
Old Feb 18, 2011 | 08:31 AM
JonathanJ's Avatar
JonathanJ
would check feed to coil as a first check , pin 2 the centre one should have 12v to it , I made a loom up so I could check and take the earthing of the coil away from ecu control , if you have feed to pin 2 then check continuity through the coil from pin 2 to 1 and from 2 to 3 , these should both be 0.5 ohms , this is the primary resistance , then check the secondary coil resistance by disconnecting all plug leads and measuring between 1 and 4 then 2 and 3 , both these should be around 10 Kohms , let us know what you find
Old Feb 21, 2011 | 05:26 PM
sirloveyou's Avatar
sirloveyou
right there is power at the coil
but still no spark and I cant hear the fuel pump kick in !
Also there is no led by the clock no flash or anything but the ecu has been tested
im pulling my hair out now !
Old Feb 21, 2011 | 06:02 PM
martysmartie
The LED by the clock should flash to indicate the immobiliser is armed, then when the ignition is switched on it illuminate solid for a second or 2 then extinguish completly thus showing the immobiliser has disarmed.
Martin
Old Feb 21, 2011 | 06:08 PM
sirloveyou's Avatar
sirloveyou
well I have nothing it dont flash and it dosent come on when I turn the key ?
is there anyway of bypassing the immobiliser ?
Old Feb 21, 2011 | 06:18 PM
martysmartie
Not easily, far better off getting it working otherwise you are compromising the security of the car.
Martin
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
