Breather drain pipe
Old Feb 15, 2011 | 03:53 PM
Rockhound's Avatar
Rockhound
Default Breather drain pipe
Since i already have my engine out and disassembled, i might as well get a connecting pipe welded on in my crankcase for my future breather system.
Do any of you know where to buy such a pipe made of aluminium and in the right size? And do any of you have some pictures of where it will be best to place it? I havent decided what breather system i will go for yet..
Old Feb 15, 2011 | 06:55 PM
You can get a off cut from any firm that uses ally pipe, cheap enough, the metal merchants will also be able to supply pipe that has bends in it.
I welded a straight pipe on my sump and am using a 90 degree bend in rubber/poly/silicone etc to suit it.
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
