Is it worth fitting vernier pulleys on a standard engine?
Old Feb 14, 2011 | 05:40 AM
pieterjan's Avatar
pieterjan
Default Is it worth fitting vernier pulleys on a standard engine?
Is it really worth it fitting them an a stage 3 engine whit standard cams?
Old Feb 14, 2011 | 06:54 AM
In short NO, the chances of picking up any meaningful power with a cam timing swing done on the rolling road is very remote, assuming you have enough piston/valve clearance to do a swing anyway, ie pocket pistons ?
Old Feb 14, 2011 | 10:04 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I fitted them on my old engine but only did it to make it look nice!!
manuel boeckx
13
Oct 3, 2015 02:29 PM
track.focus'd
Aug 12, 2015 05:53 PM
