clearing workshop,rs bits must go.allsorts here
Clearing out my workshop
Have the following s2 escort rs bits for sale
All parts plus postage or collection from Milton Keynes
Plastic water header tank £10 sold
Plastic water header tank deep bodied,unsure what car from, £10
Drivers side brand new front lower tca,includes bushes which are not pictured,ive painted it with black hammerite as I was gonna use it but had 2 of em .£10
Abs modules,pipework and brackets been cut off by me,but worked fine £20
Both abs sensors working fine £8
Two slim fans
Think there 9” and 12”,one spal,other not sure.work fine.£10 each sold
Clear rear lights,cracked a bit and look different,but might be good to someone £5 the pair including rear bulb holders sold
Standard rst discs and calipers,I started to refurb as I was gonna use myself but now got cossie brakes.
Stripped and painted 1 caliper,other needs doing.work fine though.
Discs have bit of a lip,not sure if they any good
£30 the lot sold
brake master cylinder and reservoir,works fine,£15 sold
fuel accumulator £5 sold
heater motor surround,chunk out front bit,back bit fine., £5\ sold
loads of red and black injector pipes.let me know what you want as I have loads
standard rad that has had a repair by me. sold
There was I tiny hole in one of the horizontal channels so I put some metal repair putty in it and its now fine.
Could be pro repaired if needbe.
Plastic end tanks,little bracket cut off. £15 sold
Gold battery terminals for ice installs £5 sold
Oil breather and one way valve £4 sold
Top steering cowling with hole for led.otherwise mint £5 sold
Injector rail spacer plate does not include injectors £10 sold
Xr3i metering unit.
Unsure if it works as it came with my rs,think somebody bought it thinking they same as rs. £10 sold
Standard ecu £15 sold
Fuel ecu £10 sold
Electric window module thingy,this was connected to mmy elec windows but not sure how you operate so I removed it £5
Black tailgate with 88spec spoiler and screen etc sold
Solid no rust anywhere,few scratches so would need paintin if your fussy,overall good cond though
Want back what I paid for it £70 collection only sold
see pics below
That’s about all I got,cheers guys
Two slim fans
£30 the lot sold
Xr3i metering unit.
Fuel ecu £10 sold
see pics below
Could I please have the filter and one way valve?
Also, whats this? Im pretty sure I have a yellow plug like that not connected to anything.
http://i1089.photobucket.com/albums/...n/myrst351.jpg
It arrived here in one piece.
Thanks for putting it in a "clean" box haha, smellt so nice when I unpacked it. Was like doing the washing
Makes a nice change instead of pulling out something dripping in oil.
Wife weren't happy when she noticed I emptied here box and posted it to you lol.
Cheers fella
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
