3.4 litres that all a 2wd takes?!?
standard engine with a standard sump, just seems very little to me, only registering at the bottom of the dip stick aswell...
cheers, pete
cheers, pete
On a normal oil change 3.5 litres will take it to the full mark, purely sump wise 4 litres brings it level with the top of the sump shape, ie not yet overflowing onto/into the shallow pan forward of the sump.
I measured this when my sump was off, I'd guess no more than 0.2 litre in oil filter on top of that.
It's 3.5 WITH filter, 3.0 WITHOUT (6.0 and 5.3 pints respectively) as said, never fill it right up to the max I always go just below the max level on mine, IIRC the difference between the low mark and the high mark is around 1 litre. I still have my 5 litre can from when i changed mine and have used it for top ups ever since, it's only just empty now.
Martin
Martin
Nov 3, 2015 04:08 PM
FlashRS
13
Aug 31, 2015 06:02 PM
