RS2000 4x4 Parts Clearout!!
1. Original coil pack
2. Rear Diff Cradle
3. 2 4x4 Gearbox's
4. Propshaft
5. Starter motor
6. Alternator
7. Water pump
8. Thermostat Housing
9. Got the block left from the old engine with crank etc etc - minus the sump
10. Drive shaft
11. Rear engine mount (complete)
12. Inlet Manifold
13. MK5 Rocker Cover
14. Exhaust Manifold
15. Lamda Sensor
16. RS2000 Cam's
Sure there is more. So let me know what your after.
Open to offers on everything. Postage available on most things.
2. Rear Diff Cradle
3. 2 4x4 Gearbox's
4. Propshaft
5. Starter motor
6. Alternator
7. Water pump
10. Drive shaft
12. Inlet Manifold
15. Lamda Sensor
16. RS2000 Cam's
Prices on whats left....
RS2000 Exhaust Manifold Ł45
RS2000 Inlet Plenum Ł35
RS2000 Throttle body Ł20
Inlet manifold Ł15
Starter Motor - Ł20
RS2000 Rocker cover and new bolts - Ł20
Coil Pack - Ł35
RS2000 Prop Shaft - Ł40
2x RS2000 Gearboxes 4x4 - Ł75 each
RS2000 Cams - Ł40
Thermostat Housing Ł10
Open to offers on it all. Just PM me with any prices.
Pictures available on request.
Inlet manifold Ł15
Starter Motor - Ł20
Coil Pack - Ł35
RS2000 Cams - Ł40
Most bits now on ebay.
More going up over the week. Ie gearboxes, props, drive shafts
http://shop.ebay.co.uk/jimwise16/m.h..._from=&_ipg=25
2. Rear Diff Cradle
3. 2 4x4 Gearbox's
4. Propshaft
5. Starter motor
6. Alternator
7. Water pump
10. Drive shaft
12. Inlet Manifold
15. Lamda Sensor
16. RS2000 Cam's
2. Rear Diff Cradle
3. 2 4x4 Gearbox's
4. Propshaft
5. Starter motor
6. Alternator
7. Water pump
10. Drive shaft
12. Inlet Manifold
15. Lamda Sensor
16. RS2000 Cam's
what you got left ..........
I'm interested very much a 4x4 gearbox, the trouble is that I'm from Spain could send me? would you do me a favor for that here in Spain there poqisimos rs 4x4 and can not find nada.un greeting and thanks.
155lee
Sep 6, 2016 11:10 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
