Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Escort RST wiring into mk4 fiesta
Old Feb 12, 2011 | 07:21 PM
ItsNothingWithoutATurb0's Avatar
Default Escort RST wiring into mk4 fiesta
just wondering if someone could tell me which colour wires need going to live/ignition etc.
tried looking on the forums but im not great at stuff like that.
also what driveshaft can i use for the off side?
thanks
Old Feb 23, 2011 | 11:47 PM
BUMP
only need rs turbo wiring diagram now if anyone has a link please? 7 wires left
please please help need the car for the weekend!
thankyou
Old Feb 24, 2011 | 05:50 PM
any help please?? or a forums that might be able to help? thanks
Old Feb 25, 2011 | 11:49 PM
would i be right saying BLACK to live. and browns to earth just to get it to run?
rest are oil pressure and alternator etc?
thanks
Old Feb 26, 2011 | 07:39 AM
mk1trb's Avatar
mk1trb
Boost Junkie
black is switch live, browns are earth and red is batt live, you wont be able to run much boost if your still using the standard in tank pump mate, retrofiesta had a wiring guide for putting the loom into a mk1/2 fiesta, that should help mate, green/brwn is oil pressure, dont think there are any others
Old Feb 26, 2011 | 07:41 AM
JonathanJ's Avatar
JonathanJ
Think we need a bit more info to be able to give meaningful help , that is why nobody has replied , exactly what engine are you putting into what car , what wiring have you used and how have you done the stuff so far , is it mfi as it would be from a Escort or is it an EFI conversion , what management you using etc .
Old Feb 27, 2011 | 02:54 PM
mfi engine from an escort rs turbo. standard management. and its going into a mk4 fiesta which used to be a 1.25 zetec.
thanks
Old Mar 5, 2011 | 02:25 PM
fkin car!!!
after peeling some tape back on the rs turbo loom. i have the following wires
browns - earths
thick black - live?
thick black/blue
thin green
thin black - live?
thin black/red
thin green/red
thin black/green
any help please. mainly just want it running atm need to get it moved
thankyou"!!!!
Vincereese
Jun 1, 2023 09:14 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
dlwarrior
Aug 5, 2015 10:19 AM
