Mk6.5 fiesta central locking prob
I'm having a bit of trouble with my mk 6.5 fiesta 1.25 zetec I put a new battery in the remote fob a few days ago and it opened and unlocked the car no problem .went out to the car this morning to go to work and pressing the fob would not unlock the car, I could open the boot with the key and get in via the boot (unable to open via the drivers side lock as it was given the delock look so may have to get a drill out to uncover the lock)I can start the car but trying the door handle it still won't open the doors ,just hoping someone got some ideas what I can do to at least to open the doors as it's not too good getting in and out via the boot
Regards
Regards
At Citroen we put the key in the ignition, ignition on, and hold lock on the key for 10 secs, then take key out. Then wait a minute. Allows the ecu to learn the signal again. Might work. No info in the manual?
i tried to reprogramme the fob but it did not seam to work car beeped etc but the fob did not take but while leaving the ignition switched on suddenly the doors unlocked ,so at least i was able to swap the key lock cover back to the normal one .I have orded a new fob off onlinekeycutting.com they even have the instructions for reprograming the keys ,which is handy
Steve Escos
Oct 1, 2015 06:57 AM
rsguy
44
Sep 29, 2015 03:29 PM
