suspension/diff carrier
Old Feb 10, 2011 | 07:02 AM
2Litre's Avatar
2Litre
Default suspension/diff carrier
Hi all
Does anyone know if the rear suspension/rear diff carrier/trailing arms and hubs etc are the same in on the 2wd saff and the 3 door?
Cheers, T.
Old Feb 10, 2011 | 07:31 AM
AndyPen's Avatar
AndyPen
arms have different arb locators mate - the 3 dr are outboard mounted and the 2wd inboard. These are 3dr. Other than that they are the same as far as I am aware. This is the 3dr one off my rs500.
This pre resto shot might be easier to see - look on the left
Old Feb 10, 2011 | 06:47 PM
Exactly as said, just to add that the sapphy rear arb actually does something, unlike the bit of ineffective crap on the 3 door!!
Old Feb 11, 2011 | 06:20 PM
2Litre's Avatar
2Litre
Default Rear End
Thanks for help with this rebuilt my car(Two Years,full respray in and out) and came a crop-pper five days later, am gutted!!!!!
Found myself a rear axle and trailing arms and as you say the ARB mounts are inboard(Saff) I need the drivers side TA , how difficult to find or should I Fab outboard brackets ? gutted and heartbroken!!!!! Managed to get new hubs(Front), need a bumper(front), Rad/intercooler and a jig for the front end and ARB for the rear......... other than that having a great week............... T (Sorry to vent,upset)
Old Feb 11, 2011 | 06:58 PM
2Litre's Avatar
2Litre
Default hubs
A quick one, the hubs I picked up are different to the ones I am replacing by this I mean that the connection to the TCA is not a solid 360 degree closed connection but has a bolt across clamping the TCA to the hub upright, could it be that I had 4wd hub carriers ?
Cheers. T
Old Feb 11, 2011 | 07:10 PM
Char1ie's Avatar
Char1ie
Cheers. T
You are talking about 2WD Sapph vs 3 door hubs. I assume you are replacing 3 door hubs with a pair of Sapph hubs that you have sourced. 3 doors are twitchier and aid turn in, Sapph ones are less twitchy - different geometry.
Charlie
155lee
Oct 27, 2015 04:55 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
2wdsaph ben
Aug 17, 2015 03:17 PM
Aug 10, 2015 12:08 PM
