siemen 72lb / 83lb
Are these injectors much bigger than greys ?
thinking about changing injectors to one of the above, would my standard head / cams be restrictive at this stage ?
either that on run abit more boost on the greys
spec is
low milage 200 block
fresh head
ut t38
spec is
fresh head
ut t38
The only thing with going bigger is it is harder to get the fueling correct. Especially say at idle, not much injector duration change can make your fueling go WAY out
Only applicable if you're on std management I suppose and can't get someone to map it properly
Cheers for the replys, going to get it mapped by someone so thinking may aswell upgrade the injectors before hand it's never run brilliant on the greys either
Mine runs greys, idle is 100% perfect as is whole running, can do 40mpg, mot pass was easy at 0.97% CO 137ppm, with 200K miles on the engine, T34, modded head etc, NO CLOSED LOOP gimmick in sight, even though my ecu does it, as well as adaptive, I run purely mapped.
Cold idle is perfect, even though my ISCV does not work at all.
There's nothing wrong with siemens , but if the greys flow enough for what you want, why spend money on different injectors, buy other bits instead.
Depends on which ECU u have id say, if l6 i would not go much bigger than the 55s if u want it to run mint straight through. Ask your mapper on which brand he prefers, i was adviced Siemens by mine and it runs like a dream.
Danielbetty
Oct 3, 2015 06:01 PM
timsrs
22
Sep 24, 2015 08:14 PM
