Changing ARBs?
Old Feb 9, 2011 | 04:57 PM
Bailes1992's Avatar
Bailes1992
Default Changing ARBs?
Do to the front, do I need to drop the subframe?
How easy of a job is it?
What about the rear? I had a look and it looks simple enough. Was going to get some new rear droplinks from ford as they look a little old and rust and ford only want £30 for them.
Bailes.
Old Feb 9, 2011 | 07:15 PM
Sp3no's Avatar
Sp3no
Rear is no problemo. Front is a pain in the bottom. The front subframe will need re alignment if taken off. Easiest thing is to undo the bolts not fully lowering the sub enough to get the arb out and too the bolts. Its a right pain and once again will need aligning.
Old Feb 9, 2011 | 10:47 PM
Bailes1992's Avatar
Bailes1992
So it does have to be dropped
In which case I'l get rid of the Eibachs then.
Not something I want to do
Old Feb 10, 2011 | 10:19 AM
Sp3no's Avatar
Sp3no
Yes to get the roll bar out the sub needs to at least be lowered. I have done this twice myself
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
dojj
Sep 29, 2015 10:32 PM
rsguy
44
Sep 29, 2015 03:29 PM
