clutch issues
I have not long fitted a AP paddle clutch to my zvh. Im having issues with clutch slip at a very low power level. I fitted the clutch with a fresh skimmed flywheel. There seems to be a mark on the paddles where it looks like it has been biting in one place but the whole of the flywheel has been used and you can see the wear.
i bought this off a guy breaking his car. He said it had only covered a few hundred mile which i had no reason not to believe him as there were loads of material left on the paddles and the cover was not badly worn.
Looking at the cover i cant see any markings on it to point out a "brand" name. It may be a standard clutch cover ??? No matter what cover it is it was slipping with about 150bhp. The car has not been mapped and was just on a base map so no real load was put on the engine.
I still have not got it back to gether yet to try the plate with a new cover.
Hello Juffer,
Something about the clutch and disk set up must have been wrong.
A 4 paddle disk does not require a heavy pressure plate - certainly not for
150 hp.
The disk may have been previously oil contaminated?
Or the pressure plate is for a disk with a different thickness?
150 hp.
i'm running a standard cover on an ap 4 paddle which has also started to slip.
its only covered 3,000miles, admittidly some of which has been town driving. Would the clutch slip be a likely thing to occur for this kind of use?? the car itself is a 2.0 zvh.
The first gear never felt like it would bite as hard, and felt as if there was a spongy feeling in the clutch pedal?
Could anyone shed like on this issue?
I think i may have been sold a standar cover plate with my paddle clutch. Im also running a ZVH and being a 2.1 it will have a fair ammount of torque over a 1.6 cvh. I have heared of people using standard cover plates on CVH but not on ZVH or ZETEC.
I have bought a new rachet and clutch cable aswell just incase these were to blame.
Clutch cover plates are set up for a specific disk thickness.
If the AP 4 paddle disk is thinner than the standard organic disk there will be an issue.
Could someone measure the thickness of a standard new organic disk, and compare it to a new 4 paddle disc thickness?
This may shed some light.
I had the same problem on my cvh.found to be wrong preasure plate and im running 211 torque.didnt like it one bit.got to the point it would slip before i was even on boost.hope you get it sorted.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
