Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
Breaking 3-door zetec turbo. 397bhp
Old Feb 4, 2011 | 10:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Exclamation Breaking 3-door zetec turbo. 397bhp
Will be looking to start breaking in the next couple of weeks, so if any interest in the engine/want a test drive it will be a good idea to see it running before it comes apart lol.
The car has done less than 150 road miles and most parts were new/reconned.
Engine: was mapped at Enhanced performance and made 397bhp/386lbft but had more to go!
2.0l Zetec engine:
+0.5mm Wiseco low compression pistons 7.8:1CR £500
Carrillo connecting rods £500
Big valve stage 3 cylinder head £1000
Custom BD10 grind Piper cam kit £450
Piper vernier pulleys £120
Custom sump for RWD £100
OR complete Tall block for £2500
Titan motorsport rollerbarrel throttles. Modified by having them drilled and tapped to use a vac manifold for turbo use, but could be used to connect an ISCV £500
Custom Swedish style inlet plenum to fit the rollers £300
Or both for £650
Siemens 650cc injectors £250
Tubular exhaust manifold topmount turbo £300
T3/4 Turbo £300
External wastegate £150
Hayward and Scott Custom exhaust system £500
DTA S40 ECU £500
Custom wiring loom for DTA £100
Amal valve £30
3 bar MAP sensor magnetti marrelli £50
Focus RS spark plugs £20
Ford Motorsport HT leads £30
Cone air filter £40
OR for the COMPLETE ENGINE, inlet manifold, exhaust manifold, turbo, wastegate, injectors, ecu, sensors and loom (no exhaust system)
£4500 – don’t forget this is mapped and ready to go, although will need checking to be safe.
Pro Alloy RS500 intercooler painted black. £320
Pro Alloy radiator upside down cossie rad, so will need mounts cutting off and rewelding to fit the ‘right’ way up. Painted black £300
Pro Alloy header tank/oil catch can £250
Pro Alloy washer bottle £80
Bosch 044 fuel pump £120
Fuel filter £10
Pro Alloy 50L fuel cell including fuel level sensor, filler neck and locking alloy cap £800
Braided PTFE fuel hose and Goodridge fittings £400
Fuel pressure regulator £75
Hard pipes silicon hoses £100
Collins performance 4x4 engine mounts £110
Transmission & drivetrain:
TTV Racing Custom lightweight flywheel £150 (Zetec fit to use 2wd Cosworth clutch)
Helix 6-paddle clutch £300
Cosworth T5 gearbox £250
4x4 Cosworth rear diff & driveshafts £200
3dr Cosworth front hubs £300
B&M quickshift £200
Suspension & steering:
Avo monotube coilover suspension £700
Compbrake adjustable TCA’s £150
Compbrake adjustable compression struts £150
Polybush suspension top mounts £30
Carbon top mounts £70
Momo race steering wheel £40
Snap-off steering wheel hub £100 (no keys)
3dr rear swing arms with polybushes £100
3dr rear ARB poly bushes and drop links £40
Wheels & tyres:
Ultralight 789 17” wheels WITH Cooper Avon tyres. Front 215/45/17 Rear 235/45/17 £900
Steel wheel nuts x16 £20
Brakes:
Front: Brembo 4-pot callipers with mounting brackets for 3dr front hubs £500
330mm discs £200
Rear: Brembo 2-pot callipers with mounting brackets. Will include rear hubs as I had to open one hole each side due to slight measurement error. £250
300mm discs £150
Goodridge braided brake line and fittings £350
Wilwood bias pedal box with girling cylinders, hydraulic clutch. Including reservoirs £150
Vertical Hydraulic handbrake £100
Shell:
Caged 6-point bolt-in rollcage £700 will come with free shell if required!
Vented bonnet with vents and aerocatches £150
Modified Saph front bumper to fit 3dr £50
Badboy grill £50
Headlights £20 each
Plastics 4 Performance polycarb rear windscreen and rear quarter windows £350
Doors including glass, drivers has a mk6 escort lock and 2 keys, passenger delocked £80 each
3dr scuttle panel £150
3dr scuttle ends £35 each
3dr washer jets £10
Interior:
Cobra Suzuka bucket seats, including side mounts £350 each
Willans 5-point seatbelt harness pair. 1 year left for FIA approved £200 each
Flocked dashboard, cut to go round cage, has switch/gauge holes and holes cut in the top for brake reservoirs £60
Stack ST700SR £420
Stack Boost gauge £100
Stack oil temp gauge. Comes with sump plug adaptor for Zetec sump. M14 thread £85
Stack fuel level gauge. Back light not working for some reason £60
Stack EGT gauge £85
Battery cutoff switch £15
Modified 3dr clock surround in carbon, with idiot lights. 80mm centre hole, and two 52mm holes £50 (will do deal if bought with gauges)
Push button starter button £20
3dr steering cowel. Some holes cracked £30
Oddesey racing gel battery £110
There will be bits I have forgotten so if there is anything else, just ask!
Old Feb 5, 2011 | 08:43 AM
rsmark86's Avatar
rsmark86
its a shame mate .... i know some one that could most likely repair that car....
hes doing a v6 clio thats been on its roof at the moment.... its having new roof and complete new drivers side done.....
and he dont charge the world
on one of my cars hes done then following
front wing
n/s/r quarter change
pull out o/s/r quarter
repair all the kits and bumpers that were cracked ect
some welding that need doing
including panels
2k fully painted
if tempted give me a pm mate
Old Feb 5, 2011 | 01:23 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
if he wants to buy the car whole let know lol.
im done with it.
Old Feb 5, 2011 | 01:37 PM
Kverna's Avatar
Kverna
Virgin-popper
Is the engine mount for sale also ?
If yes, are they for the original 2wd front member mounts etc ?
Old Feb 5, 2011 | 02:06 PM
rsmark86's Avatar
rsmark86
im done with it.
alright mate if you want to scrap the shell i might come have a look see... for a project when i sell my cossie
Old Feb 5, 2011 | 03:15 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
kverna, they are collins performance 4x4 cos engine mounts £110
Old Feb 5, 2011 | 03:22 PM
Kverna's Avatar
Kverna
Virgin-popper
I ment the arms bolting to the block. Sorry for not being spesific
Old Feb 5, 2011 | 04:05 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
oh right, they were custom made to fit the zetec into the sierra. £75
Old Feb 5, 2011 | 11:00 PM
Kverna's Avatar
Kverna
Virgin-popper
Can we do a deal for £80 inc. postage to norway ? If so, please contact me through pm.
Thanks for your time.
mk3ste
Oct 17, 2021 10:09 AM
chowfornow
14
Jan 5, 2019 09:01 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
