Heatshield in the middle of the floor has came off
Old Feb 4, 2011 | 09:12 PM
Orion_Gav's Avatar
Orion_Gav
Default Heatshield in the middle of the floor has came off
The heat shield on my brother's mk1 focus was dragging the floor,sounded like a shovel being dragged lol.Its to dark to see now but are these things easy to put back on?its been noisy for a while now so it must of just came off.
Old Feb 4, 2011 | 09:36 PM
RichieST's Avatar
RichieST
Just rip it off. Took them off of my old st170 as they were rattling.
Old Feb 4, 2011 | 10:06 PM
hogdog's Avatar
hogdog
It's probably rusted through so you'll need a new one.
It's a bit tricky to get over the exhaust and you may need to bend it a bit and/or drop the exhaust off the hangers to get it on but they're fairly cheap. You'll also need new hex nuts as they're not really reusable.
I wouldn't leave it off personally, you'll probably damage the underseal and transfer heat into the cabin when it gets really hot...not sure if it could start a fire but it may be a possibility.
Old Feb 5, 2011 | 01:07 PM
TXB's Avatar
TXB
ZX3 owner
I took mine off years ago. I have had absolutely no adverse effects at all. I got sick of trying to fasten them with new washers. The only one I left on was near the flex pipe so I wouldn't feel any heat under the dashboard.
Old Feb 6, 2011 | 12:30 PM
sykes2009's Avatar
sykes2009
im debating on pulling mine off i cant stand the rattling there's like 20 sections of the shite and its all rotting i tried to fasten it back up a few days ago and the edge of it sliced my finger
Old Feb 6, 2011 | 12:35 PM
TXB's Avatar
TXB
ZX3 owner
I did all that. If you do remove it, loosen some of the hangers. It will be alot easier.
Old Feb 6, 2011 | 06:33 PM
LewisT's Avatar
LewisT
the stuff is like thick tin foil you can tear it, i removed some of the sections because they were rattling no adverse effects either
Orion_Gav
Sep 29, 2015 04:50 PM
SMILER258
Sep 28, 2015 09:04 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
bassboy
Sep 10, 2015 08:54 PM
