4x4 gear box. tell difference ?
How can you tell between a sierra 4x4 box and a cossy 4x4 box. From pictures i have seen it looks like the clutch arm opening is on the opposite side (drivers) on the sierra 4x4 and it is on passenger side for cossy 4x4 box.
can any oe clarify?
can any oe clarify?
2.0 4x4 non cossie is on passenger side , it uses the same cable as the cossie 4x4
the 2.9 4x4 is on the drivers side, most if not all of the 2.8 4x4's are a type nine box rather than an mt75
as stated above clutch arm is different for the V6, i believe there is no difference in strenght on the gearboxes (cossie, 2.0 xr or 2.9xr) mt75 is a mt75 when all said and done.
but i think the ratios are different for all three box
mike elsome
Sep 14, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
