2wd coilovers????
Old Feb 3, 2011 | 06:04 PM
adam escort cosworth's Avatar
Default 2wd coilovers????
ive been offered a set of 4 2wd gaz coilovers!!! but ive got a 4wd anyone tell me whats the difference??? will they physically fit??? thanks .
Old Feb 3, 2011 | 06:40 PM
NO, not without mods.
The 4wd uses a much thicker strut body on the front, the rears however just differ in the width of the bottom eye fitting, it being around 1/2" wider on 4wd, just a guess but i wouldn't be surprised if they use the same coily and just supply a 1/4" sapcer to go on either side of the eye fitting to take up the difference.
On the front the 2wd have been used before by using a adaptor sleeve to suit the size needed, ie thicken up a 2wd strut body.
Old Feb 3, 2011 | 06:48 PM
ah i see thanks!! might just buy the proper 4wd ones then!!! thanks again
Old Feb 4, 2011 | 06:09 PM
COLEYST200's Avatar
COLEYST200
I made some spacers so i can use 2wd in 4x4 hubs
Old Feb 8, 2011 | 09:52 PM
a-mac's Avatar
a-mac
could you make another set off spacers
as i have got the same problem
thanks
Old Feb 9, 2011 | 08:11 PM
just brought a set of new 4wd avo gtz coilovers !!!!! sorted !!!
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
arfurski
Sep 26, 2015 10:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
