S.e.c.s monitor wiring
Feb 2, 2011 | 07:14 PM
Can anyone tell me how to wire this in? And has anyone got the wiring instructions they can email me
Feb 2, 2011 | 07:33 PM
send me your email address will send what i have fela
Feb 2, 2011 | 07:50 PM
Feb 2, 2011 | 09:45 PM
Feb 2, 2011 | 10:12 PM
So am I ok to just splice into the ecu wires?
Feb 3, 2011 | 05:04 AM
Feb 3, 2011 | 05:40 AM
Feb 3, 2011 | 05:47 AM
Ive emailed them to you also
Feb 3, 2011 | 05:52 AM
How do you get the ecu pins out without buggering them up
Feb 3, 2011 | 09:46 AM
Use a niddle or you can solder secs cables on the upside of the pins as i did on a couple
Feb 3, 2011 | 10:52 AM
hiya, can you still buys these, been looking for one, also what sort of price should I pay for one
Feb 3, 2011 | 12:40 PM
I just fell really lucky and got one for £50 with a small fault with the screen. But for a fully functional one expect to pay upto £200
Feb 4, 2011 | 04:57 AM
Quote:
Originally Posted by
scoobydooby914
Picture 5
Feb 4, 2011 | 10:15 AM
i need a wiring loom for one of these monitors can anybody help please ....
Feb 4, 2011 | 07:34 PM
I cannot for the life of me get the pins out of the plug, as I look at the hole where the ecu connector goes into the terminal there is a small cut out. Do I need to put something in there to release the terminal or am I doing it wrong???????
Feb 4, 2011 | 08:38 PM
Yeah mate push a paper clip in there will pop out, pm Ryan on here he will make you a loom
Feb 4, 2011 | 09:37 PM
Ive got the wiring loom, it came with it. I just really don't want to knacker the ecu pins. I tried to get one out of the plug before but it just wasn't havin it
Feb 4, 2011 | 09:43 PM
scoobydooby914
Just tap into the wiring further up in the plug, thats what i did, just cut soldered and shrink wrapped, saves pulling the pins out.
Feb 5, 2011 | 06:56 AM
Won't that affect the readings that the ecu gets? Because the signal from the engine sensors will be going to the gauge first?
Feb 5, 2011 | 07:23 AM
No mine works perfectly fine, i think the speed of the signal is far to fast for what you've said to happen, i tapped into the wirirng about 5 - 6cm's away from the pins.
Feb 5, 2011 | 12:54 PM
That sounds a lot easier. I thought it was measuring a resistance it would affect the reading that the ecu was getting
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Roscopeco
Sep 14, 2015 05:32 PM
