Focus RS mk2 decat question
Old Feb 2, 2011 | 09:27 AM
jamesm cossie's Avatar
jamesm cossie
Default Focus RS mk2 decat question
Hello
I'm sure these questions have been asked before but I might be getting a mk2 focus rs fairly soon.
The car im looking at has a full miltek? Turbo back decat exhaust.
The engine warning light is on and the owner said it came on 70 miles after fitting the exhaust due to the decat?
Does this effect running? How do you turn the light off without fitting the standard exhaust back on?
I used to have a mk1 focus rs and had the same problem and the boost used to limit while the light came on, you could disconnect the battery for 10 mins put it back on and you would be back to full boost for another 100 miles, is this all the same with the mk2?
Can you disconnect the battery on a mk2 to turn the light off like the mk1?
What should a standard car boost to on the boost gauge?
Thanks
James
Old Feb 3, 2011 | 08:54 AM
jamesm cossie
Anyone? Could do with knowing asap.
Thanks
Old Feb 3, 2011 | 09:07 AM
Carlos-Titx's Avatar
Carlos-Titx
The light is for the lambda sensor after/in the cat.
The fault code is to tell you CO2 below threshold or something like that, to say the cat is not working correctly (not sure what the actual code number is)
The car will run fine with it on, don't worry about that. As for turning it off not a clue mate. I use the DSci Platform so when mine comes on (Focus ST) I just clear the fault code with my laptop and it doesnt come on again for a while. Bit of a ball ache having to do it via laptop/odb quite often but thats what I get for fitting a decat.
Old Feb 3, 2011 | 09:09 AM
Carlos-Titx
Also if it really does annoy you with the light on the dash these have been used to turn them off http://cgi.ebay.co.uk/Ford-RS-Zetec-...ht_1090wt_1139
Old Feb 3, 2011 | 09:15 AM
jamesm cossie
Thanks mate thats a great help?
Do you know if the battery trick will work like it did on my mk1?
What is the laptop software/ interfacec you used? Any links?
Old Feb 3, 2011 | 09:22 AM
Carlos-Titx
For the ST which is what I use, http://www.dreamscience-automotive.c...g-platform.php
Says the system for the RS is coming soon http://www.dreamscience-automotive.c...mk2-tuning.php
As fir the battery I have no idea sorry mate. Never had to disconnect the battery to do it. Will pulling the KAM fuse out for a few mins work?
Old May 21, 2012 | 08:29 AM
michael782's Avatar
michael782
Along the same lines i have a Milltec turbo back on MY mk 2 rs but with a sports cat fitted. The engine warning kight has come on so i took it to have the analyser plugged in and was told the cat was goosed i am finding this hard to believe as it has only done a couple thousand miles so i was wondering if it could be the Lambda sensor?
Old May 21, 2012 | 09:03 AM
Carlos-Titx
Take it for an emissions test. If it passes then happy days. All you need then is the adapter which I linked in a previous post.
Easier and cheaper than buying another cat.
Old May 21, 2012 | 09:33 AM
michael782's Avatar
michael782
Default CAT
Thanks for that
Old May 21, 2012 | 10:05 AM
chris ST's Avatar
chris ST
If it comes on there is a fuse you can pull out and put straight back in and it will clear it. KAM fuse(keep alive memory). Think its number 26 in the engine bay. That's what I used to do in my focus st to
Old Jan 10, 2015 | 06:54 PM
rsCR41G's Avatar
rsCR41G
[QUOTE=jamesm cossie;5322527]Hello
I bought a Lambda Sensor Elbow from Autospecialist and my light has stayed off (touch wood)
Hope this helps
Old Jan 13, 2015 | 12:51 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Get it re-mapped, it will optimise the performance for any mods on the car and the light will stay off.
Old Jun 3, 2015 | 09:14 AM
RoscoST's Avatar
RoscoST
Agreed !
The code will more than likely be P0420 cat efficiency or summit like that , basically the ford ECU isn't seeing the numbers it should be from the standard cat (which is huge) - had the same on my ST with a 100 cell cat I just lived with it .
Wouldn't keep pulling KAM fuse to trick the car into thinking it's ok , get a sensor spacer as above and try that , failing that a good remap on the car will put the light out as staffy owner said it will be optimised for any performance mods . Pretty sure the usual suspects could do this for you , Jamsport , REVO , Collins , etc etc
Old Jun 3, 2015 | 11:11 AM
STeve's Avatar
Super Moderator
Keep clear of jam*port, SCC would be my choice and you get 5% off by mentioning passionford
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
gavt123
Sep 5, 2015 10:03 AM
Sep 3, 2015 10:49 AM
