wheel spacers
Old Jan 31, 2011 | 07:31 PM
dangerousbrian's Avatar
dangerousbrian
Default wheel spacers
im after some wheel spacers and bolts for my series1. it has standard wheels on but i dont think they look right with the bodykit..i want them to sit flush with the arch if possible..what size spacers should i get without compromising any safety etc and where will iget them and the longer bolts from? cheers
Old Jan 31, 2011 | 07:37 PM
RSandy's Avatar
RSandy
i think anything 5mm or above, you are going to need the more expensive hubcentric spacers. to be honest, the likes of a 3mm spacer wont make much of any sort of visual difference, so a hubcentric bigger spacer set up will be the safest way to go to keep the wheels centralised on the hub
Old Jan 31, 2011 | 08:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I have been thinking about this and 20mm will put my wheels flush with the arch and kit I think.
Old Jan 31, 2011 | 08:21 PM
focus 4x4's Avatar
focus 4x4
Ive got eibach ones if you need any, 15mm BRAND NEW !!!
Longer bolts included , boxed.
Old Jan 31, 2011 | 10:24 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Isnt it recommended that you do a stud conversion if spacing over 5mm or so as the long bolts can be a weak point?
If thats not that case how much do you want for them?
Cheers!
Old Feb 1, 2011 | 05:54 AM
zippyobrien's Avatar
zippyobrien
The eibac spacers have there own studs. Then you secure them to the hub with countersunk bolts
Old Feb 1, 2011 | 08:27 AM
Blunt.RS's Avatar
Blunt.RS
http://www.motorsportworld.co.uk/fra...es.asp?code=76
ossie cossie
Sep 21, 2015 05:07 PM
cliffy70
Sep 20, 2015 09:18 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
povey@pembrokeshire
Wheels and Tyres
Sep 9, 2015 06:44 PM
Adam Graham
Sep 6, 2015 06:04 AM
