Collins Monitor! and ECU control system!
Ask me a question!
Anyone else used these items yet? What are your thoughts?
Very similar to the Pectel monitor (reads from the ECU)
Been testing it for about a week now, with no problems or any differnet results compared to the pectel monitor!
Will add some pics soon.
Ask me a question!
It realy does work well.
Looks wicked and so slim!!
The only down side i could find is the fact that it has no way of being able to disconect the monitor from the loom once installed. If it were mine i would have to add some sort of plug for easy in and out fitment as it is a big wad of cash to leave bolted to your dash board
9/10 :
------ Pectel Monitor 10/10
9/10 :
PassionFords Creator
Ask me a question!
Originally Posted by Stu @ M Developments
Check this monitor on ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...952318078&rd=1
To me seems like the same monitor but he's charging more money for them, £450 PLUS VAT
thats £528.75 compared with collins charging £480 for the pro version or £381 for the standard version.
Madness
thats £528.75 compared with collins charging £480 for the pro version or £381 for the standard version.Madness
Stu...does it require a collins board chip to use it???????As PERFORMANCE FORD said it did...but i assume its only for the PRO version to adjust fuelling/ignition.
Oh i have one for sale too PRO version £300
Ive had mine since September/November time too.
the only issue I have is it keeps reading a TPS fault even though Ive swapped the tps it still does it. it only reads up to about 87 for tps..is this normal?
With a bit of fucking about they do fit in the dash nicely:
(its not the best pic as it looks better in the flesh)
Originally Posted by Neil S
Stu - I was reading the old post there and you said you were working on compatibility with your closed-loop software... Did you get this finished?
Due in no small part to the fact i didnt even get it started
