Poly bushes
Old Jan 31, 2011 | 11:10 AM
Ollie L's Avatar
Ollie L
Default Poly bushes
Afternoon all, Im about to order a Powerflex kit for my 4x4 Sapphire, if i remember rightly i read in here a while back the there is a certain place on the car that i dont fit them because otherwise it drives to hard and vibrates?? Or am i going mad!
Im gonna be using it on mainly on road and occasional track days so i dont want it rock hard that i feel every bump it the road. Any help would be much appreciated...
Old Jan 31, 2011 | 11:17 AM
charlie luciano's Avatar
charlie luciano
Poly bushe everything except the rear trail arms
Luciano
Old Jan 31, 2011 | 11:19 AM
Stu @ M Developments's Avatar
PassionFords Creator
Luciano
Agreed, and fit a proper triangulation mount too.
Old Jan 31, 2011 | 11:25 AM
charlie luciano
Nice 1 Stu
Ahmed Bayjoo 6 degree rear beam is what I really wanted for Xmas
Luciano
Old Jan 31, 2011 | 11:39 AM
JamesH's Avatar
JamesH
Triangulation mount?
Old Jan 31, 2011 | 12:19 PM
Sorry, differential mount to most of you guys.
(its not a diff mount of course, but hey ho... LOL)
Old Jan 31, 2011 | 02:50 PM
On at least 15 sierra/cossies I have driven with poly arm bushes, I have yet to see any issue, and use these here myself, but it's up to each personal choice.
Old Jan 31, 2011 | 04:03 PM
Mike1's Avatar
Mike1
Nice 1 Stu
Luciano
Or go the whole hog, fit a good diff mount, AB 6 degree beam, poly bush the car, fit AB spring set with Konis
Old Jan 31, 2011 | 04:24 PM
A simple question here should suffice for you to see what we mean.
The part in question is under very heavy load and subject to considerable forces as you know. Do you think a poly bush of any form could ever be as accurate at aligning a rotating part under such loads as a spherical bearing?
Old Jan 31, 2011 | 05:23 PM
Gav Diamond's Avatar
Gav Diamond
It doesn't matter what you get bud as they will only sit in your grandad's garage and never get fitted anyway, lol
You'd have a awesome road car if you fitted all the parts you got in boxes
Old Feb 2, 2011 | 11:36 AM
JamesH's Avatar
JamesH
Got one
Old Feb 2, 2011 | 05:49 PM
Ollie L's Avatar
Ollie L
Awesome cheers for the input people just what i was after..
Ace!! i'll get one as these aswell on the suggestion nice one!
Cheers Gav!! Ya bastid!
Old Feb 7, 2011 | 09:18 PM
Ollie L's Avatar
Ollie L
Luciano
I forgot to ask, if im not to poly bush the trailing arm bushes what do i use in its place instead??
Old Feb 7, 2011 | 09:19 PM
Nothing if your bearings are in good nick, if not, new spherical bearings.
Old Feb 7, 2011 | 09:27 PM
Ollie L's Avatar
Ollie L
Great! Thanks for the help, and info about the triangulation mount aswell matey .
Old Feb 8, 2011 | 04:36 PM
Gav Diamond
If your trailing arm bushes are gone dude you need these ones
http://cgi.ebay.co.uk/GGR1092-Ford-C...item5add9890c1
http://cgi.ebay.co.uk/GGR1093-Ford-C...item5add9890cf
Not cheap though
Old Feb 8, 2011 | 07:29 PM
charlie luciano
As said just replace with standard trail arm bushes the last time I checked from ford one side was available while the other was not, iirc i think its the inner one you could get but not the outer, GGR do direct replacements of these bushes
Luciano
Old Feb 8, 2011 | 07:31 PM
charlie luciano
Doh Just noticed Gav's link post above mine previous post
Luciano
Old Feb 8, 2011 | 07:52 PM
dojj's Avatar
dojj
Resident Wrestling Legend
fuck me!!!!!!!! £320 for a set of trailing arm bushes
you might as well get a proper beam for that price if you are going to spend money on it
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
