Ap 6pots on S2??
Old Jan 30, 2011 | 02:11 PM
Scott_Rst's Avatar
Scott_Rst
Default Ap 6pots on S2??
Hey,,
been offerd ap 6pots (330mm) discs from my old man as he going to return his Escos back to standard-ish form,,, was wondering if they would fit behind 17inch Rs-7 spokes on my S2?
any advice would be greatly appreciated
cheers
scott
Old Jan 30, 2011 | 02:17 PM
maxest's Avatar
maxest
Originally Posted by Scott_Rst
Hey,,
cheers
scott
RS 7 Spokes arnt the best for clearance on big brakes, so i'm 99% sure they wont go on
You would have to get new bells and brackets i would assume from the likes of reyland,, then some comps or similar to go over them
Old Jan 30, 2011 | 02:26 PM
Scott_Rst's Avatar
Scott_Rst
cheers for the help! i think ill give it a miss! the 4 pots are more than capable
cheers
Old Jan 30, 2011 | 08:55 PM
dave_s2_rst's Avatar
dave_s2_rst
6pots
Dont think you will need them on an s1/2
I run 4pots/325 discs on RS7's and its tight!
alittle pict to show
Old Jan 30, 2011 | 10:22 PM
Scott_Rst's Avatar
Scott_Rst
[quote=dave_s2_rst;5318684]6pots
yea mate was thinking it would be massive overkill,,was only thinking about it due to the cost of the set up and the fact i wouldve been getting it for nothing!
cheers
Old Jan 31, 2011 | 05:52 PM
THEDMAN's Avatar
THEDMAN
I run FRS Brembo's with standard 324mm discs and they are tight.
I do think you have a hope in hell of getting even the callipers behind RS7's.
Old Feb 3, 2011 | 07:04 AM
jonny s2's Avatar
jonny s2
ive seen 4 pot AP's on an s2 with 330mm discs, RS7s are quite hard to get huge brakes on, but seeing as your old man already has them, suppose theres no harm trying, post up if you get them to fit
fostersice
27
Dec 26, 2009 06:00 PM
McGoo 69
18
Mar 18, 2009 07:50 PM
R5FORD
25
Feb 6, 2009 08:22 AM
Mr C
11
Apr 13, 2008 07:52 PM
chrisreid
Ford Escort RS Cosworth
55
Nov 17, 2007 05:01 PM
