sierra cosworth vac pipe inlet mainfold
Old Jan 25, 2011 | 05:29 PM
shlongie's Avatar
shlongie
Default sierra cosworth vac pipe inlet mainfold
Hi guys, can anyone help me, ive had my saphire cosworth in bits for 7 months, ive got the engnie in, but ive got one pipe missing, it lives on the inlet mainfold, just below the air temp sensor, can anyone tell me were this pipe should go to.
cheers steve
Old Jan 25, 2011 | 05:33 PM
jon@work's Avatar
jon@work
you need
1. fuel pressure regulator
2. map sensor
there is also as standard a breather one-way valve - blank off if not being used
you may also have a boost gauge and dump valve pipe
Old Jan 25, 2011 | 05:38 PM
shlongie's Avatar
shlongie
hiya, its a fairly fat pipe right under the air temp sensor. can i just blank it off???
Old Jan 25, 2011 | 06:17 PM
jon@work's Avatar
jon@work
if you're not using the standard breather, yes
Old Jan 25, 2011 | 06:23 PM
shlongie's Avatar
shlongie
cheers jon
charliecosworth
Aug 19, 2015 02:00 PM
cossie4x4
Aug 14, 2015 06:29 PM
155lee
Aug 14, 2015 11:21 AM
dal3door
Aug 13, 2015 06:55 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
