sierra 3 door rollcage specialist????
Old Jan 25, 2011 | 07:55 AM
ital_cossie's Avatar
ital_cossie
Default sierra 3 door rollcage specialist????
hello,
i'm writing from italy, i started planning my new cosworth rally car it will be a sierra cosworth 3 door gr.A replica. I would like to have an answer from the sierra specialists!! who can make the best cage and bodyshell preparation?? The car will be a rust free 1.6L sierra and i want to fit the following:
_ multipoint rollcage with front cage penetrate the dashboard and triangulation to the turrets
as the late ex-works escort cosworth wrc.
_ front wrc turrent extensions for wrc top mounts
_ pedal box
_ rear arb chasis mounts (i will use a mag 2wd 909 beam with 9'' diff) on the front i will use a gr.A bolt on type.
_ side holes for wrc stands
_ chasis engine mounts
i found custom cages in UK and also saw a white 3 door they build on PF sept. 2009 with an excellent result!!!
also i know thet gordon Vincent is specialist for the escort cosworth wrc prep. As i want to have the best base to build my project i want your opinion.
thanks
hopper350
Sep 4, 2015 12:53 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
andyrs1600i
Aug 30, 2015 07:21 PM
Vincereese
Aug 12, 2015 01:55 PM
