convert to efi?
Old Feb 1, 2005 | 06:57 PM
markyboy's Avatar
markyboy
Default convert to efi?
what is needed to change my set up to efi so i can get some proper chatter going, or can it not be done without changing loads?
any help or advise much appreciated as usualy guys
Old Feb 1, 2005 | 07:58 PM
rst230bhp's Avatar
rst230bhp
Hello mate
im looking into doing this conversion aswell for my s2
i found a site with good info on it, have a look
im sure it willl help
http://www.chardcars.co.uk/
ON-UJAH's Avatar
ON-UJAH
Unless you have a grand going spare, I'd not bother thinking about it too much...basically you need a Fiesta Turbo, and transplant the engine and ECU etc.
Converting a RST block and head to EFI isn't going to be worth it.
You could do Zetec Turbo for a better price these days.
Old Feb 1, 2005 | 08:06 PM
Puss2's Avatar
Puss2
Formerly know as Puss
if you pm gadget im sure he will help you out with wats needed
Old Feb 1, 2005 | 08:12 PM
markyboy's Avatar
markyboy
bloody hell didnt relise that much needed to be changed
Old Feb 1, 2005 | 08:29 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
i have 4sale a full frst management setup (loom, ecu,efi unit,MAP sensor, plugin 15psi chip (reflashable to any spec i think) if it helps any1
then just need the 1.8 cvh cps reallt i would think, i just fitter frst engine and management to mine but goin back to mfi now a special lump has surfaced
also have a frst full engine 4sale to0
Old Feb 1, 2005 | 08:32 PM
Lee @ Fusion's Avatar
Lee @ Fusion
fook me , hear we go again ,
1 last time i will say whats roughly needed ,
Will a mod PLEASE PLEASE add some conversion notes to the technical archive .
For starters a FRST engine and head will be needed , block so u have a Crank position sensor and the head/ inlet so u can use electronic injectors ,
a cheeting way is to use a XR2i or a Xr3i ( efi ) engine and fit low comp pistons or a set of standard RST ones .
The Flywheel from these EFI engines will also be needed ,
The best loom to use is a XR3i ( efi ) escort one , the whole loo will fit straight into you RSTand will be the easiest to fit ,
Dont forget youll need the clocks aswell as the rev counter will only be half true if you use the ERST standard ones ( EFI uses wasted spark and only measures 2 of the sparks so to speek)
Now u have the new loom their are 2 wires to change ,
firstly find pin 27 in the main ecu plug , brown wire !!!! move this to pin 8 ,
Next go to the EDIS module and find the second wire in , ( blue and yellow , ) either remove this or cut the wire and tape it up .
that is the loom now up to FRST spec .
Youll obviously need a Fiesta ECU , OFAC or OFAB , and a map sensor ( OFAC and OFAB ae different so get the right one )
U need the FRST inlet charge temop sensor aswell ( available from ford) these are NOT THE SAME as the rst ones , U NEED THE FRST ONE !!!!!!!!!!!!!!!!!!!!!
Plug it all in , plumb all the engine in and turn the key ,
it realy is that simple , if you want any more info please feel free to call on the number below .
oh forgot to say thet the turbo will need to have a return plumbed in
hope this helps guys
Old Feb 1, 2005 | 08:34 PM
1.9 xr2 on 40's
st170 breaking
can getaway with the cps fitted to the pully too like on 1.8 cvh's
no blocks need messin with then
Old Feb 1, 2005 | 08:40 PM
ON-UJAH's Avatar
ON-UJAH
Converting a EFI XR3i or XR21 is much easier than doing a ERST to EFI - due to the reasons Lee just described. It's still gonna cost you over 500 quid, unless you get a OFAC/OFAB, turbo, hosing and piston set cheap.
Old Feb 1, 2005 | 08:42 PM
1.9 xr2 on 40's
st170 breaking
for 500 ill supply a full frst lump and all the management to run it
Old Feb 1, 2005 | 08:45 PM
JesseT's Avatar
JesseT
You don't have to do it the hard way. You could just always get a complete cvh efi inlet, bigger injectors and a management like the under 100Ł Megasquirt and your done. The inlet fits the head nicely without any adaptor plates. Just grind away a little material from the head.
Old Feb 1, 2005 | 10:41 PM
TILLIO's Avatar
TILLIO
Not necesarily, ive made up a complete CPS bracket setup, with billey modified ERST pulleys and an adjustable alternator bracket, using the 1.8cvh parts as a base. Saves swapping engines, and the pulley and bracket can be fitted in situ.
Adapter plate for the efi manifold, save grinding the head, and getting swarf in the bores.
Just need to get the 5-6 wires for the multi plug sorted
mondeomark
Sep 28, 2015 06:28 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
Neil Clark
Sep 8, 2015 07:06 PM
hopper350
Sep 4, 2015 12:53 AM
