Bottom end
Old Feb 1, 2005 | 06:45 PM
The Sludge's Avatar
The Sludge
garibaldi
Default Bottom end
right guys, i need sum help please. I am gonna attempt to rebuild my bottom end on my series 2
Can anyone tell me exactly what tools i need etc and how easy/hard it is to do please?
Old Feb 1, 2005 | 06:48 PM
I would recommend a haynes manual mate.. www.haynes.co.uk
Old Feb 1, 2005 | 06:52 PM
The Sludge's Avatar
The Sludge
garibaldi
got one dude already- anyone got any tips? anything to look out for??
Old Feb 1, 2005 | 07:04 PM
I would say the important thing to remember is to work in a clean environment to prevent ingress of dirt/grit. Take a methodical approach and leave nothing to chance.
Old Feb 1, 2005 | 07:08 PM
Eagle's Avatar
Eagle
Super Moderator
its really easy .. i did mine .. a good socket set .. torque wrench .. i renewed everything except the crank.
need to find a good engineering company to do any machining work..
also had the complete bottom end lightened and balanced from clutch to pully
and dont forget to put the oil splash guard back in (small bit of plastic that clips over the inside of the lower oil breather hole)
when takin it apart label or mark the crank so you know where the main caps went
keep everything totally clean when asembling , i washed everything in parafin first then oiled before fitting. and clean anything out from the bottom of the thread on the headbolts .. erm ... thats about it really
hth
Dead and Gone's Avatar
Dead and Gone
mkIIxr2turbo,
dood change ye siggy size lol
EDIT:- arrgh you done it
Old Feb 1, 2005 | 07:16 PM
The Sludge's Avatar
The Sludge
garibaldi
cheers eagle
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
