T5 speedo sensor
Old Jan 23, 2011 | 02:51 PM
mattman1234's Avatar
mattman1234
Default T5 speedo sensor
Has anyone changed their t5 cable to an electronic sensor ?
If so where can i get one
cheers matt
Old Jan 23, 2011 | 03:33 PM
I'm researching this at the moment, I'm convinced there will be a lecky drive that will fit directly in place, my mates loaning me a type 9 speedo drive, as these can be got cheaply in lecky drive, to see how similar, if not from what I've seen can be modded easy, I'm doing this for myself, even if it means machining a adaptor boss up, but with that being the case it will be defo easily possible.
I'm certain there are some GM T5's that fit.
Old Jan 23, 2011 | 03:36 PM
focus 4x4's Avatar
focus 4x4
ive changed my 4wd speedo cable to electric , dunno if that helps?
Old Jan 23, 2011 | 06:50 PM
Looking at the sensor pictured the 4wd must be a different cable end to the 2wd one, that has the inner sticking out about 1/2" or so, and a bell shape that sits in the speedo drive, a circlip goes on top of the bell part and secures in the inner groove of the drive part to hold together.
TVR I would have thought would have looked into this when they used the T5, but assume they had no luck ?, as they used a ring around the output flange on the diff and a sensor picked up off of this.
It's a very easy job to locate a sensor somewhere else, such as counting the prop bolts etc, then just calibrate, most can be done with a bit of simple maths or even a sat nav to hold at a set speed then "zero" the speedo gauge in that way, can also build in a little safety margin that way as well!!
Old Jan 24, 2011 | 06:20 AM
tigra turbo's Avatar
tigra turbo
Did mine with an external sensor as tabetha said from the driveshaft bolt with a traducer is am saying it right.
Old Jan 26, 2011 | 03:45 PM
drift mekanik's Avatar
drift mekanik
I have just posted a similar question. If anyone cracks this problem, please let me know as I need the answer and with limited knowledge, I am no good at fabrication or adaptations.
Old Dec 13, 2013 | 01:41 PM
SHEPNEEDBEER's Avatar
SHEPNEEDBEER
Just doing mine, same sender unit but you buy an adapter from Burtons to accept it. Shep.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
