dirt seals...ap brakes
Bully
Wim, mine say this on them because they have no dust seals. I think you know me well enough to know that I am not under the car servicing them every weekend as well
Originally Posted by Porkie
Don't worry mate... If I had a dust seal sitting right in front and it was labelled 'Dust seal' I still wouldn't know what it was
you just press start
PMSL laughing. Did you ever see the Gumby's sketches that monty python did. I now have this vision of you bashing parts of the lock and barrel shouting "get-in, get in!!" FPMSL
as long as you brake clean (fluid)and re copper grease around the piston then you will not have any problems
when you come to change pads clean all crap and deposits of the pistons before you push them back into caliper
then re copper grease and put pads in
