fitting AP big brake kits
Old Feb 1, 2005 | 04:59 PM
MATCOS's Avatar
MATCOS
Default fitting AP big brake kits
Ok,I have my new 355mm brakes and 6 pots,how does it all go together?
For example do the bolts that hold the bracket to the hub go in so the nut is on the wheelarch side or the wheel side?,do the threads all need locking for safety?,the rotors are grooved is there a specific way they need to go on ?
Any other helpful hints please?
Mat
Old Feb 1, 2005 | 05:01 PM
Damo V's Avatar
Damo V
re the rotors, they go on specific to the cooling vanes NOT the grooves... i'll try and find a pic for ya
Old Feb 1, 2005 | 05:07 PM
Damo V's Avatar
Damo V
Disc Handing
Most AP Racing Brake Discs feature Curved Vanes. The brake discs are handed and should be installed with the cooling vanes running back from the inside to outside diameters in the direction of rotation as indicated in the sketch.
Old Feb 1, 2005 | 06:56 PM
MATCOS's Avatar
MATCOS
nice one Damo
Mat
Old Feb 1, 2005 | 09:21 PM
MATCOS's Avatar
MATCOS
up for some more clever peeps please
Mat
Old Feb 1, 2005 | 09:37 PM
THE RADMAN's Avatar
THE RADMAN
i put threadlock on the hub/bracket bolts just to be on the safe side
Old Feb 2, 2005 | 05:38 PM
MATCOS's Avatar
MATCOS
Cheers - I think it would be best too
Mat
Old Feb 2, 2005 | 05:58 PM
Tony Ryan's Avatar
Tony Ryan
The normal discs for 355mm x 32 mm are cp 3581 family , and are floating discs, the diagram above shows these, the slot indicates the need for a "Bobbin " kit to be used to allow the disc 0.4mm movement on the bell .
If im wrong and its a "hole" in the disc , then the nut is usually fitted away from the hub face pointing inwards so it dont catch anything on the bell face .
hope all is clear !
Old Feb 2, 2005 | 06:09 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
and the tourque setting is only 10nm ish
Old Feb 2, 2005 | 06:21 PM
MATCOS's Avatar
MATCOS
thats more like it ,I just dont wanna do it wrong,thanks for all the info-any more
mat
Old Feb 2, 2005 | 06:23 PM
Rs Gus's Avatar
Rs Gus
thats for the bell bolts
Old Feb 3, 2005 | 05:29 PM
MATCOS's Avatar
MATCOS
Cheers Gus
mat
Dr. Ickxs
Aug 15, 2015 11:34 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
Blown Hell
Aug 5, 2015 07:22 AM
