can you remove saph pedal box in one piece?
Old Jan 20, 2011 | 04:13 PM
5tox's Avatar
5tox
Question can you remove saph pedal box in one piece?
Ive been pissing about replacing a clutch quadrant for a while now and after finally getting it all back together under the dashboard i discovered i had forgotten to attatch the spring on the clutch pedal, this cant be amended unless i take the whole lot apart again so im really not having a good time,
The whole lot has to come out again...
Is it possible for me to build it all outside of the car and stick it back in as a complete unit (the pedal box)
Someone suggested it before but there was absolutely no room to manouvre it in around the steering (shaft/column thing)
has anybody removed or installed a pedal box in a saph before and is it possible to do it as a complete unit?
Will it involve removing the steering shaft thingy which connects the steering wheel to the steering rack and how difficult will this be?
Old Jan 20, 2011 | 05:11 PM
Paul_RS's Avatar
Paul_RS
Yes its easy.
Take the lower dash section out, thre are 3 bolts into the bulkhead and one into the steering coloum iirc. No need to remove the steering column.
Old Jan 20, 2011 | 05:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
3 17mm nuts and one 13mm bolt tucked away that you have to look really hard for in the dark
but yes, once it's out (disconnect the brake rod) it's a 10 minute job on the bench
Old Jan 20, 2011 | 06:49 PM
nicksaph's Avatar
nicksaph
if you can loop a cable tie onto the spring you can pull it down and hook it onto the clutch pedal, it is a little bit tricky but it is possable. it might be worth a try befor taking out the pedal box
cheeRS nick
Old Jan 21, 2011 | 07:50 AM
5tox's Avatar
5tox
its just that i tried to fit it as a complete unit before but it just diddnt want to go around the steering column, ill give it another go though as it was a right pain in the arse trying to stick it all back together underneath the dash.
Last time i tried i think i still had the lower dash connected (its removed now so should give me a little more room)
original
Apr 28, 2026 05:20 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
matman
Sep 9, 2015 05:45 PM
YODI
Aug 30, 2015 01:12 PM
Aug 29, 2015 08:16 PM
