mk6 fez window b/pillar trim ?
Old Jan 20, 2011 | 03:54 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
Default mk6 fez window b/pillar trim ?
The b-pillar trims, externally on my sisters mk6 fez (2 dr if it makes any difference) keep basicly unclipping themselves - the bottom mostly, it seems to just unclip and then flap about in the wind, which is really fucking annoying !
Is there any way to stop them doing this other than bonding them on ?
Old Jan 20, 2011 | 04:22 PM
RichieST's Avatar
RichieST
Very common fault! Kept happening on my wife's old fiesta, we lost 2 in a year!
I tried sticking them down but it never worked. Bought a new trim from Ford after one was lost on the motorway and that stuck fine. It was quite cheap too.
Old Jan 20, 2011 | 04:33 PM
Zetecfiesta's Avatar
Zetecfiesta
about 30quid for the pair i believe, most fiestas i see in the MK6 have lost a few lol
Old Jan 20, 2011 | 06:45 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
It's only the drivers side that's causing a problem. I'll tell her to buy a new one - do you get the clips with it or are they extra ?
Old Jan 20, 2011 | 06:54 PM
RichieST's Avatar
RichieST
Yes they come with the white clips already glued to the trim, I should imagine it's the glue that has come unstuck on hers!
Old Jan 20, 2011 | 07:19 PM
Mk1-stu's Avatar
Mk1-stu
Patronus
cool. cheers ears
Old Jan 21, 2011 | 09:02 PM
steves24V's's Avatar
steves24V's
the top of one of our 08 plate focus doesn't sit back properly, clip it back and in 2 hours its the same.
Old Jan 3, 2016 | 03:57 PM
ATS123's Avatar
ATS123
I had the same issue, just had some new ones ordered with clips. Is there a good/better way to remove the clips from the car of the broken trim?
Old Jan 3, 2016 | 05:34 PM
RichieST's Avatar
RichieST
Either pop them out with a screwdriver or pull off with a pair of pliers.
Old Jan 3, 2016 | 07:34 PM
pcbp97's Avatar
pcbp97
use tiger seal or similar, this will secure them properly.
Old Jan 3, 2016 | 10:23 PM
ATS123's Avatar
ATS123
Thank you, all done now and fitted perfectly.
chowfornow
14
Jan 5, 2019 09:01 PM
Nov 1, 2015 06:53 PM
cossie330
Sep 27, 2015 04:13 PM
