kaz*a
IIRC i read somewhere this little fooker needs LOADS of spyware to work properly
ones that the software programs won't detect.
might be wrong mind............................
it installs loads of crap on ur pc it is full of adware as afew of my mates found out there is a lite version which isnt as bad
for all ur needs try www.filelist.org
u need to keep a 0.2 ration of uploads to downloads but itll max ur line out no probs 24/7
in fact its a lot worse than kazaa, you`ll be a fool to use it
if you are using it or are thinking about using it you should read this article, it will change your mind: http://methlabs.org/forums/showthread.php?p=55588
kazza lite k++ spoofs me 1000 files and NO smart arse hacker crackerhas a chance to search my h drives
better than the older type of software
