drive belt ford fiesta1.8d mk4
Old Jan 19, 2011 | 06:51 PM
fffiesta's Avatar
fffiesta
Default drive belt ford fiesta1.8d mk4
HI,
My tension pulley broke the other day and I am looking to buy a new one(and belt ) on eurocarparts.
I have mesured the tension pulley to be 73mm 22mm but the choices on eurocarpart ask if its alternator powered or steering pump powered? and also with or without aircon/pas - does this mean aircon OR pas or aircon AND pas?.
my car does not have aircon and the alternator and power steering is powered by the belt.
the reg i used on eurocarparts uk is n778 mav.
thanks in advance for help on this.
Ian
Old Jan 19, 2011 | 06:58 PM
Can you not take the bits off the car and take them to the shop so that you get the right ones.
Old Jan 19, 2011 | 07:05 PM
stephenbatey's Avatar
stephenbatey
So you tell them you want the belt for a non a/c car that has power steering, it's not exactly rocket science
Old Jan 19, 2011 | 07:20 PM
fffiesta's Avatar
fffiesta
yeah ok stop crying lol i wanted to order it online tonight ! and the belt that came off my car comes up pas/aircon when i search it so confused me a bit! maybe it had the wrong belt on hence having to get the garage to tighten it up when i bought it!
Old Jan 19, 2011 | 07:33 PM
stephenbatey
Just ring them in morn and it'll be sorted, and it won't have the a/c belt on as it'll be much bigger that the one for your car. I work selling car parts.
And why would I be crying? I ain't broke my drive belt tensioner
Old Jan 19, 2011 | 07:48 PM
Brendan's Avatar
Brendan
struggling with reality
worst case is you take a picture, phone them up then Email it to them!
Old Jan 19, 2011 | 11:38 PM
fffiesta's Avatar
fffiesta
Thanks - I sort it out tomorrow
Old Jan 20, 2011 | 09:12 AM
CarParts Express's Avatar
CarParts Express
£46.70 delivered if u still stuck...just give us a bell
Old Jan 24, 2011 | 04:02 PM
fffiesta's Avatar
fffiesta
thanks - all sorted - I put a new tension pulley in (only 15.18 before tax) . but used old belt for now as they sent wrong one! way to short - seems my car takes the longer belt even though it does not have air con! weird! - I could not reach the tension bolt with allen key (from the bonnet/top) so found a niffty little trick to turn the bolt from the threaded end(from under the car) - it was shaped like a allen key so used a socket that fitted it and presto!
cos elle
Sep 1, 2015 06:48 PM
A.t.p
Aug 15, 2015 11:37 AM
Versus_Creations
24
Aug 5, 2015 09:32 PM
fatboy billy
Aug 3, 2015 08:34 AM
