Gaz coilovers
Old Jan 19, 2011 | 05:01 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Default Gaz coilovers
Anyone used them, good or bad ????????
Thinking of getting some for the saph
Steve
Old Jan 19, 2011 | 05:09 PM
D16PJM's Avatar
D16PJM
i have gaz on mine and when they first went on i had them set to hard and they were a nightmare but when set correctly i find them to be o.k, you welcome to take a spin in mine if you want steve as iv just mot'd and tax it again.
Pete
Old Jan 19, 2011 | 05:10 PM
Moonstone Steve.
Which ones you got Pete ?
Steve
Old Jan 19, 2011 | 05:12 PM
D16PJM's Avatar
D16PJM
im tight steve so just standard not gaz gold
Old Jan 19, 2011 | 05:13 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Gaz Golds are nice Coilovers Steve, but expensive!!
Old Jan 19, 2011 | 05:37 PM
BRAMMER's Avatar
BRAMMER
I got non gold Gaz and they are set low and hard and take some getting use to
Old Jan 19, 2011 | 06:23 PM
KSA-Cossie's Avatar
KSA-Cossie
I've got gaz golds and love them.
Old Jan 19, 2011 | 06:48 PM
Ridgey's Avatar
Ridgey
I've got std GAZ coilovers cos i'm tight as well.
Found them great, on the softest setting they are good on road.
Old Jan 19, 2011 | 06:51 PM
BLACKCOS's Avatar
BLACKCOS
i had gaz on mine for years not a problem with them great on the track as well
Old Jan 19, 2011 | 07:21 PM
Moonstone Steve.
Sweet, thats it then fuck it going to get me some (budget Gaz as i'm tight lol)
Steve
Old Jan 19, 2011 | 07:38 PM
BRAMMER's Avatar
BRAMMER
They were the only ones available when i got mine - also if your buying new question the rate of the the springs as i think they sell the kits with the wrong springs for Cosworths - i remember a thread regarding it years ago
Old Jan 19, 2011 | 07:54 PM
Moonstone Steve.
Thanks m8, good advise, what are good rates for a 2wd saph, mostly used on road with the odd track day
Steve
Old Jan 19, 2011 | 08:20 PM
Ridgey's Avatar
Ridgey
Mine came with 300 F, 200 or 250 R i think.
Mike Rainbird advises slightly softer at the rear, can't remember his comments on the fronts.
Old Jan 19, 2011 | 08:44 PM
Sticky.'s Avatar
Sticky.
I've got standard gaz & i hate them, i've spolit a nice road going car, i've got softer rear spings (180lb)to put on mine & hopefully it will make a difference.
Koni's & ahmed springs off Mike R is the way to go.
Old Jan 19, 2011 | 08:59 PM
Moonstone Steve.
Paul, i already have Koni's and ahmed springs and if i'm honest it handles really really well, just thought some coilovers would be the next step up, maybe not, dont want to waste Ł600 and it be worse.
Steve
Old Jan 19, 2011 | 09:08 PM
Sticky.'s Avatar
Sticky.
If it was me i'd keep the perfect set up mate.
I'd gladly swap with anyone who had that set up....im sorry i sold mine now.
Old Jan 19, 2011 | 09:10 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Spec-R intercooler then
Steve
Old Jan 19, 2011 | 09:30 PM
Moonstone Steve.
Steve
Fuck that, will put up with slightly high acts and a little less power
I aint chasing numbers
Steve
Old Jan 20, 2011 | 09:12 AM
gibbo frst's Avatar
gibbo frst
i wouldnt bother either unless you get a real good deal.. ive got gaz golds and it drove much nicer on the ahmed/koni setup.. next time mine is off the road ill buy new konis ect and swap it all over as doubt mine will ever go round a track..
Old Jan 20, 2011 | 12:19 PM
rsmark86's Avatar
rsmark86
ive got gaz coilovers on the 3dr and my back end is very lively ......
ive been told i need a 6 degree beam to make the most of the coilovers but thats a min of Ł800/1000
Old Jan 20, 2011 | 12:24 PM
Char1ie's Avatar
Char1ie
Mine feels perfectly good with gaz coilovers and standard beam. What spring rates and damper settings are you using?
Charlie
Old Jan 20, 2011 | 12:47 PM
rsmark86's Avatar
rsmark86
Charlie
pass .... lol it came with them but if it loses traction it fish tails quite badly but it is running 415bhp@1.5 bar but its going to mad soon for something to be fixed and will be at 2.2bar and 500+ again
so this needs sorting pretty soon so i think a rear beam and a diff mount are on the cards
Old Jan 20, 2011 | 12:58 PM
Char1ie's Avatar
Char1ie
If you jack up your car and look at the spring rates you may be able to cure the problem by ordering softer springs. Sounds like they may be too hard. Much cheaper than a new beam
Charlie
Old Jan 20, 2011 | 01:03 PM
rsmark86's Avatar
rsmark86
true mate i will get mark at mad to check when he remaps it
Old Jan 20, 2011 | 02:12 PM
dazzle740's Avatar
dazzle740
I personally would put the money towards 6 degree rear beam and arms and enhance the already good koni/ahmed set up
Old Jan 20, 2011 | 05:22 PM
rsmark86's Avatar
rsmark86
i agree
the guy on here (mr rs licker) sells them complete for Ł800 and thats bloody cheap
Old Jan 20, 2011 | 06:32 PM
Ridgey's Avatar
Ridgey
Sorting the handling is more important than more power, thats for sure.
Common sense really.
Old Jan 20, 2011 | 11:44 PM
paddyrs's Avatar
paddyrs
i have avo coilovers they are good but rub a bit on the rear arches i dont like that and am not goen to batter them in so am goen back to my koni/ahmed set up
Old Jan 21, 2011 | 06:05 AM
BRAMMER's Avatar
BRAMMER
I have totally the opposite with mine, it just sinks down and pulls straight through with a little kick at 2.5 bar but nothing to really worry about as it straightens up quickly - what wheels are you running on the back? strut brace, bushes??
True i wouldn't like to be pumping 500+ through a car that fish tails badly
Old Jan 21, 2011 | 11:29 AM
Ridgey's Avatar
Ridgey
Brammer: exactly
Old Jan 21, 2011 | 04:59 PM
rsmark86's Avatar
rsmark86
its on gaz coilovers and polybushes and now has compomotive th2's with dunlop maxs on but when it had standard wheels with r888s it wasnt to bad ..... so its got to be the wheels and tyres
but if i keep it im going to put r888s and a 6 degree beam on it
Old Jan 21, 2011 | 05:11 PM
gibbo frst's Avatar
gibbo frst
think i might invest in an adjustable beam this yearas mine is useless in first and second which i did like at first but now while mine is killing the tyres any other car starts pulling away.. i was thinking of getting some 9 inch wide rear wheels but realisticly cant see that the odd few mm tread on the road making that much difference.. dont want fat tyres hanging over the 8s that i have..
yatta
May 21, 2016 10:31 PM
mk1turboestate
Dec 2, 2015 08:31 PM
S3an
Sep 26, 2015 11:39 PM
lime
Sep 25, 2015 06:56 PM
CrOwSoN15
Sep 24, 2015 01:36 PM
