Cossie calipers on a series 1
Old Feb 1, 2005 | 02:12 PM
steve rs's Avatar
steve rs
Default Cossie calipers on a series 1
does anyone know what is needed to fit a set of escort cossie calipers
on a series 1 ie brackets spacers etc
thanks
Old Feb 1, 2005 | 02:16 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
think its just a spacer to move the caliper , speak to Brom@ZOO
Old Feb 1, 2005 | 06:48 PM
CliffRS4's Avatar
CliffRS4
Escort cossie calipers , 2wd cossie discs and a spacer for each of the bolts.
You can use washers.
I had this on mine and the washers were only a couple of mil thick.
Only used one washer one each bolt on mine.
Old Feb 1, 2005 | 07:07 PM
xr4x4rs's Avatar
xr4x4rs
i think there 1 mm washers you use
i havent got any on my set up went straight on
but work brilliant anyway
AJC
Oct 8, 2015 11:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
muzzman1
Sep 30, 2015 08:59 PM
