need an M12x1mm male brake pipe fitting... where from??
As title, replacing all the brake lines on a friends Fiesta cosworth that i'm building back up for him.
I'm changing the whole lot over to braided lines, i can find everything i need on rally design except an m12x1mm convex male fitting. ( To go into the master cylinder / pump for the rear brakes )
the m10x1mm fittings are £4.30, i found one m12 fitting here.. but £26
??? http://www.bueni.co.uk/car/m12x1-brake/2
Even a m12 to m10 adaptor would do but drew a blank there too! Any suggestions? Or banjo fittings would do, i could make all three fittings on the pump banjo fittings!
Cheers.
??? http://www.bueni.co.uk/car/m12x1-brake/2Even a m12 to m10 adaptor would do but drew a blank there too! Any suggestions? Or banjo fittings would do, i could make all three fittings on the pump banjo fittings!
Cheers.
