General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I wouldn't if you are going to use it on the road. Stick to a 35mm drop as lower than this your geometry will be miles out, the car will drive like crap and you'll chew through tires at a crazy rate.
It's already sat on 60mm springs with no problems on tires.
Plus, I can soon have the geometry alligned to suit.
Really? The Camber and KPI aren't adjustable and negative camber increases as the suspension compresses (goes lower). I've had a few Fiestas and ran an XR2i at 50mm briefly and it drove like a pig.
If you just want to slam it as has been said just grab a cheapo set off e-bay, it'll bugger the rest of the car in no time so expensive kit is a waste of time and money
