solid gearbox mounts
Old Jan 16, 2011 | 09:07 AM
bad boy rs's Avatar
bad boy rs
Default solid gearbox mounts
Anyone used these on 2wd ? theres some on ebay for 25 quid as im tight i may give it a go
obviously there gonna be noisy but arnt the polly ones nearly solid anyway
Old Jan 16, 2011 | 10:15 AM
Dan@Rapid-Ford's Avatar
Dan@Rapid-Ford
Noooooo!!!!! I had the bush design changed changed in the Vibra gearbox mount as the orig were too hard and the vibration was unreal, so a solid bush would worse.
IMO the new bush makes it liveable and is a definate improvement over the std rubber bush.
Old Jan 16, 2011 | 10:57 AM
What's wrong with a decent condition std bush, this is what I use and have no issues at all, might poly fill it if I did have trouble, as this is only £10 to do.
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
DavidK
Sep 27, 2015 02:55 PM
