what zetec for my escort?
Old Jan 16, 2011 | 01:49 AM
scoobypete's Avatar
scoobypete
Default what zetec for my escort?
was wondering what engine would be best for my mk4 escort.it had a 2l zetec on carbs in but thats blown up now so was wondering what would be quickest? a 2l zetec with a HO inlet or a escort gti engine as if im correct its a 1.8?
thankyou peter
Old Jan 16, 2011 | 01:51 AM
scoobypete's Avatar
scoobypete
or an rs 2000 engine?
what would be fastest out of the 3?
Old Jan 16, 2011 | 02:34 AM
alexno1dj's Avatar
alexno1dj
rs2000 most powerful standard (150bhp), 1.8 zetecs can make 150 bhp with tuning, different engine mounts needed for the i4 (rs2000 engine) 1.8 is same as any other silvertop where mounts are concerned
so would slot straight in where 2litre was
Old Jan 16, 2011 | 08:58 AM
massivewangers's Avatar
massivewangers
If the car was already Zetec converted, then 2.0 has to be the simplest option. I'd skip the 1.8 if you can, might as well fit the biggest engine possible. If you're staying NA, you need everything you can get to start with. Inlet wise, I doubt you'd notice much difference between the 130PS or 115PS inlets. I have heard people say that the 115PS flows better, but not sure how much truth there is in that.
RS2000 engine is worth considering. Believe it takes a bit more work to the engine mount, but it will go, and you can use the usual suspects of gearboxes from RS Turbos and the like, so no worries there. Also means 150bhp and 140lbs/ft out of the box. They seem to respond well to pretty basic modifications, and there's been plenty of engines producing in the region of 170bhp on a standard inlet and things. It's worth considering, given how cheap the parts are at the moment. That and they sound amazing when you give them some stick!
Old Jan 17, 2011 | 12:07 AM
scoobypete's Avatar
scoobypete
well im going to go 2l zetec unless i can get an rs2000 lump, does anyone know the work involved getting one in?
Old Jan 17, 2011 | 07:06 AM
big difference in the inlets as i unknowingly had a 115 on mine, changed to a 130 big big gains ,the ports are phisically bigger as is the throttle body internals
Old Jan 17, 2011 | 07:08 AM
you have to run the 1800 sump and oil pump, and also fettle the engine mount ,wiring side of things i googled a lot of it
Old Jan 17, 2011 | 12:47 PM
scoobypete's Avatar
scoobypete
yhe got all that, as i have a 2l zetec in atm on bike carbs, its just fukked lol so selling the carbs and hopefully have your manifold
Old Jan 17, 2011 | 05:39 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
deffo go 2.0 silvertop with the RS1800 spec inlet side of things mate, as per our pm's and what twins said....as long as you get all the 130 spec stuff its the best out of the 3 in my opinion.
RS2000 engine bolts straight up to S2 box but rear mount takes a bit more work, plus you need to suss out an alternator set-up. Not sure its worth the extra aggro over the Zetec, however the I4 sounds mint
Old Jan 17, 2011 | 05:47 PM
bigkev's Avatar
bigkev
i know wer u can get an rs2000 block, also ive fitted a 2.1 zvh n im planning 220 at the wheels , it has run 273 at wheels seen rolling road graph b4 i bought it so mayb 2.1 would b the balls, dunno bout flaffing bout wi rs2000 for wat ever power , good luck with watever u choose bud , somtimes u can listen to to many people, listen to wat u thinks best,
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
gingerturbo
Aug 11, 2015 09:44 PM
