air injectors
hi can anyone let me know its possible to have two different boost levels if im running air injectors i just need to be able to turn the boost down in the wet but id still like the air injectors to controll the wastegate or do i need to move onto an electronic boost controller?cheers mac
why not just stop putting your right foot down so hard?
I asked my tuner to do a 2 stage boost set up for me.. his reply was no problem when you learn to control your right foot you can have as many boost stages as you like
the problem ive got is its a very light racing car with a t4 turbo i dont care how gentle you are with your right foot when it comes on boost in the wet you aint going any
where quick
so im still thinking if i come up with an idea i will let you know
You can have a 2 stage boost control, quite easily from what i remember? But for accuracy you may want your ECU modded for a 12 position boost switch?
Your right foot has bugger all to do with it
You'd need to be a god to control boost with the throttle, much easier to have the like of a 12 pot boost controller. Means you can still have 100% throttle and whatever boost you set it too.
Why not simply turn the boost off near totally, for wet conditions ?, a simple bit of wiring and a switch in the amal valve wire will do this cheap enough.
On one of my 3 ecu positions the boost is bled on build up so it is a lot more gentle, even if your foot is planted.
mk3ste
Oct 17, 2021 10:09 AM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
