Saph 4x4 strange noise
Old Jan 15, 2011 | 12:29 PM
mattrst90spec's Avatar
mattrst90spec
Default Saph 4x4 strange noise
Hi
My 4x4 saph has developed a strange knock in the front end, if you driving along and flick the steering left then quickly right you get a single knock noise which you can also feel with your feet but it doesnt do it all the time, its also done it when when i was on full lock doing a u turn in a road junction.
Got it up on a ramp & gone through every joint, bush & mount and cant find anything wrong, checked for things touching other things & nothing.
Any idea?
Regards Matt
Old Jan 15, 2011 | 12:53 PM
As you, I suspect something has a little play, often a pita to find, are the suspension tops nice and tight ?
Old Jan 15, 2011 | 02:36 PM
MannheimAlex's Avatar
MannheimAlex
Take a look at the downpipe, it is pretty comon that it touches the floor.
Old Jan 15, 2011 | 03:15 PM
kjc300's Avatar
kjc300
Check the downpipe isn't too close to the tunnel - common prob
Old Jan 15, 2011 | 03:30 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
had the exact same with mine it was the exhasut banging for me
Old Jan 15, 2011 | 03:45 PM
mattrst90spec
Cheer's guys, im pretty sure the downpipe isnt causing the problem but will double check tomorrow, i half think the suspension tops could be the problem, they seem tight when jacked up & with weight of car on standing still but there isnt the weight there is when changing direction.
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
landaqmabba
Sep 15, 2015 07:16 PM
dojj
28
Sep 11, 2015 10:00 PM
truffleshuffle
Sep 10, 2015 09:35 PM
rsturbo27
Sep 5, 2015 05:08 PM
