master cylinder
Old Jan 15, 2011 | 07:56 AM
NEEDFORSPEED's Avatar
NEEDFORSPEED
Default master cylinder
i have a 3/4 clutch slave cylinder, what size master do i need to use?
Old Jan 15, 2011 | 01:54 PM
You would need to know the stroke, of the slave cylinder before you can size it perfectly, so to be sure you can push enough fluid, but as a rule if you use the same stroke/movement at the pedal then you're obviously going to get the same range of motion at the salve end, if in doubt go slightly larger at pedal end, ie next size up, or alter pedal pivot point for more/less stroke as needed.
Stroke of slave normally around 35-40mm.
Old Jan 15, 2011 | 02:09 PM
graham c's Avatar
graham c
wots it going on
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
