Those using www.sig-generator.com **PLEASE READ**
Guys,
As many of you have noticed I have been removing lots of signatures created on sig-generator.com because they are massively oversized!!
I have just created a signature on this website and its very easy to get it to fall within Passionford limits.
Firstly - on the drop down menu for "Signature Dimensions" make sure you select 550 x 150
Secondly - on the next drop down menu for "Image Quality" make sure you select Low : JPG
I did this and with my first attempt my signature was 33KB infact my current one is under 26kb!!!!.
Just to reitterate the signature sizes that Passionford allows -
Max signature physical Size: = 550 x 150 pixels
Max signature Disk size: = 35840 bytes (35k)
To check the size of your signature just right click on it and choose "properties".
Hopefully if you can follow these simple rules whilst using sig-generator.com your signature will be well within the allowed limits and I can stop upsetting people by keep having to remove them.
Thankyou
Thankyou
