Brake pipe fittings sizes, Question.
Whats the two sizes used on Fords? i know one is m10x1mm but i need to know the other size, the bigger one. The female fitting is 15mm hex, but what is the thread size?
Ie, the bigger fitting on the cossie ABS valve blocks, i want to order some fittings to make a braided line front to back.
Cheers.
Cheers.
track.focus'd
Aug 12, 2015 05:53 PM
