Can anyone reccomend a code reader? ST170 fault code problem
Old Jan 14, 2011 | 01:03 PM
white2lsr's Avatar
white2lsr
Default Can anyone reccomend a code reader? ST170 fault code problem
The EML is showing on my ST170 and the dash is showing DTC 9359. Can anyone recommend a good cheap code reader so I can read the codes properly.
Can anyone with previous experience of this code possibly shed any experience?
Cheers for any help.
Old Jan 14, 2011 | 02:12 PM
RichieST's Avatar
RichieST
I bought one of these off ebay for my old st170, think it was less than Ł20. Worked fine!
Old Jan 14, 2011 | 02:24 PM
ECU Monitor Enthusiast
DTC 9359 is the code so no need to read it again !!!
Nearly all readers will give you a code number but not what the code means.
I would find out this actuall meaning first before doing anything else and only buy a code reader if you really want your own or need to reset a code that is classed as "persistant".
Most codes auto reset when you fix the problem and drive a few miles or disconnect the battery for a few minutes.
(Make sure you have radio code before disconnecting battery..etc..)
Google is your friend and here are a few hints I found...
http://forums.focaljet.com/team-tech...tc-9359-a.html
http://www.focusfanatics.com/forum/s...ad.php?t=45005
Sounds like you have a fuse out
dombanks
Sep 21, 2015 08:38 PM
Tank Mike
Sep 10, 2015 07:56 AM
focus2351
Sep 9, 2015 09:33 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
