Escort cambelt cover
Jan 10, 2011 | 09:25 PM
Will a full length escort cos cambelt cover fit my saff 4x4? Somebody told me they wont
Jan 11, 2011 | 06:41 AM
Jan 11, 2011 | 06:48 AM
They should do.
To make life easier, I trimmed mine to it only attaches to rocker cover and the centre bolt
Jan 11, 2011 | 08:06 PM
i have one on my 4x4 engine in my 3 door i didnt have to trim anything
Jan 12, 2011 | 07:38 AM
Got one on mine, bit fiddly though mount in the same places as the 2wd one. Usually rub on the bottom pulley
Jan 12, 2011 | 07:42 AM
Can someone post some pictures of how they look
Jan 12, 2011 | 11:24 AM
Jan 12, 2011 | 06:54 PM
Quote:
Originally Posted by
bad boy rs
they only rub if the convex washer isnt fitted between the main pulley and cambelt pulley, mine has a good 4mm clearence at least
Jan 12, 2011 | 07:21 PM
bad boy rs
That's a 4x4 saff cover
Jan 12, 2011 | 08:06 PM
Same as escos cover,do you mean a latter small turbo cam belt cover
cheeRS stu
May 25, 2017 | 12:19 PM
Reviving old thread, but will the small turbo cam belt cover fit earlier engines without modification as it lacks the two top bolt holes?
May 25, 2017 | 04:05 PM
Cossie92
I have seen it done on Turbosport, a guy fitted the t25 rocker cover and front cover onto a 3dr.
Vincereese
Jun 1, 2023 09:14 AM
jessie_rs
11
Jun 3, 2019 04:57 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
